Sportcross Rear Wiper Problem
Bit of a problem with lexy's rear wiper, it's going slow and making nasty grinding noises from the motor itself....anyone else had this problem ?
Hopefully it's lubrication so any tips about getting the hatch rear panel off appreciated and we'll have a go when it stops raining / blowing a gale !!
You can remove the rear wiper quite easily, just lift the plastic cover and remove the nut that holds the wiper in place. Below that you'll find a big flat nut (from memory), remove that and the large metal disk, then you can drop a little oil into the spindle. That should do it.
Good luck
jack
Good luck
Jack
Thanks jack, I will have a go....when it stops raining !!
