Stupid Question
Most digital cameras save as JPEGs as default. However their compression is not as much as it could be. Probably to keep the data level up for post processing.
After transfering to my PC I always resave it as a .jpg again as it will use a different compression ratio (which can be altered by user if want more/less) to reduce the file size.
You can get a near 2MB JPEG down to about 200K like this and still not have to use an offensive ratio!
