Is200 Wing Mirror Cover
I believe so.
But if your getting it sprayed, just send it as a whole, they can easily mask it up. Then replace the whole mirror?
Thanks Stav,
The one on the car has been glued permanently in place and doesnt fold *forgot to test if the mirrors folded before buying* The one in the pic is a used one that i have been offered by a breaker but cant stand the scuffs of it so just wanted to know if i could easily swap the blue bits from mine to the scruffed.
I believe so.
Thanks Stav,
If you remove the glass then there is 3 screws(i think its three???) holding the blue colour coded part on, remove these screws and the cover should come off and then just swap them over! Think there is a little clip that holds it on although this will probably break when you remove the cover but its not needed.
Jason :P
I believe so.
Thanks Stav,
Jason :P
Oh cool, thanks alot Jason!
