Mrs Macs car failed the MOT on Sat, 2 x front lower ball joints (easy fix) and excessive play in NSR lower suspension arm. Did a check and it's the one on the Sub Axle Assy that's shot.
Read a few threads on here re this one and it looks like you need to replace the whole stub axle just for the bush.
Has anyone managed to track down a supplier for replacement bushes?
Sounds very similar to the problem I had (see thread also titled rear suspension bushes).
If it;s the same location as mine (see drawing in thread) then getting poly bushes maybe difficult due to the requirement of this bush to provide some rear wheel alignment (camber I think).
I bought some poly-urethane bar from an engineering supplies and was going to turn some up on a lathe.
After looking at the problem I saw the alignment requirment first and then thought I'll give it a go anyway.
Then I tried to remove the knackered bushes ......... couldn't budge them at all.
Wouldn't be suprised if it could only be done with a press.
Let us know how you get on.
TM
TM
Yup I did read your thread on the subject mate and it is the same one. Looks like the whole Assy then :crybaby:
