Has any one received a recall letter f to correct a manufacturing fault with a fuel pipe located in the engine compartment?
The recall affects 3,921 cars manufactured between 03/06/05 and 02/12/05. It relates to a faulty seam weld on the fuel line. The recall is dated 15/04/08 on the VOSA register. The VOSA site lists all VIN affected. Recall also included IS 250, same dates.
If you want to check you need to put manufacturer as Toyota not Lexus.
Regards Dave.
