Fitting New Hid's
Hi im having a bit of trouble and wondering if anyone can help at all.Fitted it all up got it all working the only problem is i cant get the new bulb to locate in the hole/socket.The old one fits in then twists to locate but the new one will fit in but not twist.Can anyone help me on this or am i just being a bit dumb??
Cheers all
Cheers all
Dont know mate. But if you campare the two bulbs (old and new) side by side, you should be able to see the locating bits, if they are there.
Got me a little worries now, cos i think ive bought the same kit as you!!! waitin for it arrive, should be next day or two. when it does, ill let u know if i have the same problem or not!
Mine wer a bit tighter than normal, should fit in ok mate.
What HID bulb type did you buy and from whom ?
Don't force it and break your bulb/headlight !!!!
Its a different shape bulb but the fitting is exactly the same. It fits straight in but just wont twist to lock in. They were off eBay, a hong kong seller which said they were made to fit the lex
I would advize you to take your car to a MOT centre and get them set
I had mine fitted and thought they were great
But when it went for a MOT the allinment was out got them set and they were even better
how do they set them once there in i thought they were set already as the old bulbs are
