Condensation In Headlight
i was told (although i've not tried it myself) if you put a towel or something similar over your lights whilst having them on for a while the heat build up should dry it out.
but be very careful as you could melt the headlight.
i think mine may have had this problem as the p/s side one has a slight melt like mark.
if u dont want to take apart your headlight, u can use the simple method
remove lowbeam high beam and city lights of your headlight,
take a hair dryer and heat up your headlight,
heat it up tilll al condens is gone,
mount your bulbs again and it should be ok.
it should take 15 minutes to do
