2004 Ls430 Nav Screen No Power Please Help
hi and welcome to loc, the 04 ls430 is a lovely car, same as mine. when you bought the car did you know the screen had a fault. if not i would recommend contacting the seller. sorry i can not be more specific as this is a rare thing to go wrong on a lex.
Anuj
Hi
Welcome
Just been looking at the wiring diagram for your car and it seems there are three 7.5 amp fuses that take power in different forms to the center console, and two relays, I'm not that good at reading these new fangled diagrams so can't actually tell you where they are.
They could be in either kick panel, under the bonnet, sorry hood, or in the boot sorry trunk....
Anyway just have a good look for a broken fuse and if you can't find one you will have to go to the dealer, over here they have a standard price for diagnostics which is about £55 so probably around $100. Would be worth it for the air con!!!!!
Good Luck
Pete
