Blown Fuse
RS200 turbo
Hey Folks
Was replacing a switch the other day and got my wires crossed! Blew out all the Lights on the dash, I had a look at the fuse box under the bonet but could not locate the necessary fuse, or any blown fuse for that matter!
My first question is:
:question: Where would I find the fuse for the lights on the dash of an RS200?
and secondly,
:question: These fuses are like baby Blade fuses, are these easily sourced?
Any help would be much appreciated
Cheers
Dave
There is a fuse box in the footwell behind a panel, have a look there.
The fuses are standard automotive type and can be got from Halfrauds or any motor factor.
Hope that helps
Hope that helps
so on the altezza, there is 3 fuse boxes, 1 in the engine bay, one in the drivers side footwell to the right of the pedals nearest the door and one on the passengers side foot well, closest side to door too. little panels pop off and on the back of them should be diagrams showing you what each fuse is for. The fuses are mini blade fuses and can be gotten from any motor factors. get a few though incase it pops again, 7.5, 10 and 15amp are the most common ones, you might find a few spare ones in the fuse box under the bonnet
