Have they taken ALL the keys, or just one set? You will need at least one master key to have new ones made - master keys are the ones with 3 buttons so they can open the boot as well. When you buy the car new, you get 2 master and one slave key.
If you have one of the masters still, you can get one made up at a dealer quite easily. Otherwise, it could prove seriously expensive and probably best to run it through your insurance company...
Thanks for responding. When I bought this car 6 years ago I was only given 1 key and now the last key has gone aswell. I spoke to this company who can make me a key with a transponder for £350. But as you said it is quite expensive.
Always thought you needed new ECU if no master key available - plus you'll need all new locks otherwise they will always be able to get in your car.
Does the £350 also include "deleting" of the old keys from the car so they will no longer work - If not and your car gets nicked then you may not be covered under your car insurance.
