Help Noise On Steering ?
Lexus2D
When u turn it 2 full lock u get a noise like a belt slippin :question:
But when u lift bonnet & bounce it on full lock is more like its comein from pipes :question:
Hard 4 me 2 explain :whistling::blush:
Can sum 1 look 4 me @ the meet on Sunday Pretty Please :unsure:
Hi 2D i believe this is normal .....mine does it...but dont keep turning the wheel on full lock you are putting to much of a load on the pump etc
or it could just be a slightly loose belt or may need spraying....gave mine to lexus and they put belt spray on....and then fitted a new pump but still does the same?
:winky:
I have the same problem, ive put it down to a loose power steering belt.
Rob, what does that mean? Id like to look into it more, but no idea where to start.
I thought that 2 but just had all my belts replaced & its still doin it :unsure:
ok u have a steering pump that pumps fluid to 1 side or the other of the steering rack depending on the position of the steering wheel, if you go to full lock you are putting fluid all on one side so valve is fully open - somewhere is a pressure relief valve, if the valve is fully open presure is only on the 1 side and that pressure builds up so u need someway to relieve it. whether it be by pump design or a primative pressure releif valve - as the pressure is released u can get a resonance ( or a chattering) of the valve this can sound like a squeal.
turn the steering wheel slowly to full lock, when the sounds starts stop turning the wheel and then rev the engine a fair bit what happens then???
mine has never made a sound so i cant check this - would be interesting
Cheers will chek this 2mora :)
Is it something that has suddenly started or it has always done it? Is the power steering fluid topped up to the correct level?
Did it b4 i had my belts done so thought that would sort it but is still doin it on & off duno how 2 chek fluid :question:
look in the owners manual under servicing it shows u everything there...
and of course if it has only just started to do it after a service then i woud get it checked out, there are quitea few people on here that have had exactly the same sounds
Yeah iv seen the steerin & u r correct Rikos :)
No it did it b4 2 thought it would have sorted it :unsure:
Backed it out this morn when it did it i reved it like u said & it squeeled even more :huh:
