I've recently bought an 06 220d with MM - As a matter of interest, can anyone confirm that there should only be 1 DVD in the system. I was surprised to find that a Toyota Avensis I drove recently had Europe & the UK split over 4 discs.
I assume it may be the case, as it seems that the 220d disks cannot be easily changed, whereas the front panel on the Avensis flips down for easy access to change them.
Hi Boothby,
See existing topic: http://www.lexusownersclub.co.uk/forum/ind...showtopic=46133
Matt
As Matt has correctly and kindly supplied the topic link, by viewing it you will get your answers. Just to briefly clarify that if you order 2008 update you will receive 4 discs. North, East, West and Central. That's what i received. Prior updates 2007 and before, only 1 disc received.
