Photo Software
Rob
hi all,
i have a photo that is a negative but i want to change it to look like a normal picture/colours etc - i have had a look on the net for something but cantt find the correct search words.
anyone know a programme?
cheers rob.
Einstein - I have V9 - do you know if it works on that, and how's it done? Do you scan it in?
If you have a physical negative (as opposed to an image file that is negative) and you put it through a photo scanner, then the scanner will produce a positive image file in jpg, tif or similar format, ready for printing.
Is the negative part of a strip? Or is it a larger single negative? I am assuming that you are talking about a colour negative (i.e. a sort of orangy colour)
You need to find someone with a photo scanner. Alternatively, if you don't mind paying, Jessops should be able to scan it for you.
Paint shop pro will do it with one click...
If you really get stuck, you cound email the pic, and I'll do it and send it back..
John
sorry i was unclear - i have a jpg photo file that looks like a negative, but i want to change it so it looks like a normal photo - can u do that in photoshop?
