Got a good quote for all four Dunlop SP Sport MAX A fitted and balanced at Lexus Belfast(iam trying these instead of the potenzas).
quote worked out at £405 .I think this is reasonable.
Hi nicnac,
Give Central Tyre Services (Howard Street South in Belfast) a shout on 028 9023 8508. I have been using them for a few years now and have found them to be very good. Just recently purchased 4 new Toyo Proxes T1R tyres for my IS250 Sport from them. So far they seem to be very good and worked out a bit cheaper than straight replacements to the factory fits.
To be honest I didn't price with Hurst's this time as I have found them a shade more costly in the past so not sure how things stack up at the moment.
Central also do a great job on the alignment... ask for a guy called James.
I know the SE takes a different tyre size from the Sport but it may be worth a call...
Having said that I use Hursts for everything else and find them excellent.
Good luck,
KevM
Hi nicnac
How many miles did you get out of the Potenzas?
Hi nicnac
Got about 31,000 Km(20,000 M) so far .
They are not completely down to the tie bar wear indicators but not far off.Toe in wear is noticable so i will have to get the tracking done.
