Tte Bumber
Rob
hi all,
i am after a pic of the TTE bumper without a number plate fitted - what i need to know is does the tte bumber come with the same big cutouts etc for a UK plate holder? I am hoping it does not.
Im asking as my front plate is only 30cm long x 8cm wide so on a normal bumper with the plate holder removed you end up 2 larg cut outs on each side.
you wont see these cut outs unless u remove the plate holder BTW
No they dont mate.
There is not cut out just a bit that comes lower than the lip for about 15cm so you've got a bigger space to stick the plate too.
I've only got a little plate on mine and before i cut out the whole lip it still fit fine.
ah perfect - i might have a look at getting one otherwise im stuck with whats below , all depends on cost of course!
i hardly see an other is200's about but ill have to check and see what they normally do here
