I noticed my Full beam light on the dash was not working so i check my lights and the driver side wasn't working so today i changed it out with 3 different bulbs which i know are working but the light is not can anyone tell me of a fuse etc which could be the fault? Thanks and appreciate any response.
Hello Rod :D Theres a fuse box on both sides of the car in each footwell side panel, if you take the cover off them it tells you on the reverse side which fuse is for what if i remember right? :unsure: or theres the main fuse box in the engine bay but think it'll be one of the ones inside the car :)
Thanks Chris, i found the fuse and it is a 10amp under the bonnet. Noticed today that brake fluid was a little low so i topped it up. my TRC and handbrake lights have been flashing and have not had TRC working for a while and i had tried resetting ECU etc but nothing corrected it. Until i topped up brake fluid today and hey presto !!!! its fixed so its been a result!!!
