If you do a search theres a few old threads on installing one. The pipe you tee intos a bit of **** cause there's not much slack but its do able.
Ive got mine mounted in a TIM mount between the middle and speedo (similar to where Ellz has a gauge)
I just pulled the bulb out and put a wad of LED's in its place.
Rob (fluff) was saying theres a dead easy place to take the boost feed from......
yea, might swap for LED's instead possibly, i presume they'll fade ok with the dimmer?
Yeah i remember him saying that, cant remember where though.
Yeah they fade ok with the dimmer, just like the rest of my dash ;)
just this second popped out and brought it.
was an absoloute bargain at $17!!!!
doesn't have a t-piece connecter though.....well none that i can see through the packaging. is that how they all are? the autometer and ultralite gauges all came with the same accessories....
rob, could you message me the details where i can take a boost feed from please mate???
i don't think there is a t-piece, so i'll get hold of one from somewhere. i guess i'll need one that has an end that fits in the tubing supplied with the boost gague and an end that fits in the outlet from the boost pipe???
hi rob send me ur email again, as its a pdf. u can tap into the pipe near the throttle body but its a bit awkward as the pipe is short. other option is near the bulkhead access is also a bit tricky, its the pipe for the map sensor.
which is easier rob???
does the pdf come with full instructions on how to get the tubing feed into the cabin and source illumination feed also??
pm sent
cheers mate
Can you send me the Pdf about the bulk head fitment for the boost gauge, just interested in where it is.
