I'm off to MPH 2007 tomorrow and am hoping to find a cheeky little boost gauge. I'm not wanting to spend big bucks, just something that will give me an indication of any boost loss and something that looks good in the cabin.
I just wondered if i need any extra bits and pieces in order to get it fitted? I presume it will come with t-piece and boost pipe, but where does this attach to on the supercharger?? Is it an easy job to do?
Cheers
Rob
Cheers
Rob
Yes, even you could fit it mate :lol: Just make sure you get all the parts with it.
Re fitting to supercharger not a problem, its been covered on LOC somewhere, think Zee made the post.
Gordon.....you know i'm getting better at this DIY malarky!! :P Lets face it, couldn't get any worse :lol:
i did have a quick search but didn't find anything that answered my question.
All the gauges i've looked at so far come with t-piece, boost pipe and wiring. Is the feed into the cabin easy to do and connection to power feed for illumination etc??
u need the T piece to plumb into the vac line and the power is only for the internal light - make sure u get one that is low pressure as the SC only goes to .35bar so a gauge thats 2 bar is worthless.
Cheers Rob, i was thinking i needed a low pressure gauge.
Where is the vac line on the charger mate?? The gauge's i'm after have an illuminated screen/dial and need a power feed from 12V source i presume. Is this easy to get without making a big mess, lol
Boost gauge from a escort RS? :D have only 1bar, but the look is very very :blink:
greets
Tom
yes the 12V is very easy i would take it from the cig lighter as access is very good but depending where u plan to put the gauge there may be a better place to take the power from.. pm me ur email and ill send u a pic of the easiest place to tap into the vac line.
but be aware even if its a 1 bar gauge u may not see if the system is leaking unless its a fairly big leak, but some indication is better than i guess i did find a 0.5 bar gauge but it wasnt designed for a car
greets
Tom
LOL i've just installed that one this week. Gonna take it apart though and get a stainless face made for it. was the only 1 bar gauge i could find.
As for fitting, it's a little fiddly getting to the pipe but its not massively hard to do.
And as for the twelve volts, i just attached it to the pot that adjusts the brightness of the lights by you left leg, that was it dims and brightens with your dials.
The vac lines a right little fiddle bugga. If you look to the right of your throttle body there are a few rubber hoses down there.
You want the small one that goes from the block to the bottom part of the throttle body (i think it goes to the block, it looks like it just loops back on itself) its about 15 cm long so doesnt give any slack at all and its pretty tough so getting a small t piece in there is also not fun.
You'll know soon enough if you've got the right one as the boost gauge will either move or not at all LOL.
Sorry photos not great but this one i taped into first time around was wrong
You can see theres quite abit of the hosing that goes down the back, its the wrong one.
This on the other hand its the buggar.Sorry about the crap photos but there really no room to even get a camera phone down there.
You can see its crosses the other hose but this one really wont budge its small cramped and darn fiddle but good luck :D You'll get there in the end.
Yeah basically at the side of the throttle body you'll see two hoses going to a little bit of equipment, you want the one that goes to the bottom of that equipment.
no joy at mph i'm afraid. the company that were there last year weren't there this year :crybaby:
i'm going to look around for a low pressure unit and see what i can find.....they seem to be a rare commodity as i haven't come across one yet!!
I got this little beauty fitted to mine :D
wozza do you want the instruction books for those gauges?sorry forgot to bring them up that day.
He sure will, he has been trying to get some of HKS :shutit:
there is a far easier place to take the pressure from..... let me know when u get the gauge and ill send u a pic of where
cheers rob, ur a gent :D
Can you send me the pic please rob?
  • 2 months later...
will this gauge work fine with the s/c?
Sunpro Gauge
Is it the mechanical one i need and is it easy enough to get a 12V feed for the illumination??
anyone got a good link for a single dashmount or a pilar mount pod holder??
TIM do a single dash mount, but if you search eBay theres loads.
Doesnt matter if its mechanical or not but i'd recommend a mechanical one, unless you go for a high end electronic one, for accuracy.
The lower price electronic ones tend to be less accurate.
As for a 12v feed, i took mine off the dash brightness adjuster so it adjusts with the rest of the ignition lights.
TIM do a single dash mount, but if you search ebay theres loads.
cheers stav. is the gauge easy enough to install??
how do you have yours mounted??
i'm going to get a mechanical one i think and then play aroun wih different bulbs until i find a colour combo i like between the dash and the gauge....
