I've had my wheel tracking/alignment done this week. It was quite a way out and had to replace one tyre because of it. :( Since I have had the tracking done my steering wheel doesn't sit quite in the centre. It doesn't pull to one side or anything, it just sits slightly turned to the right.
I took it back to the local garage to have it sorted. After another 20 mins and a few adjustments later, it has made no difference. They tell me that the wheels are aligned perfectly now.
Should I take it back to the garage and ask them to adjust it some more, or is this something they can't fix and should I take it to someone else look have a look at it.
Ifraz :unsure:
Ifraz - they have not done the alignment properly mate..... either get them to look at it AGAIN or take it to your dealer and they'll do a full 4 wheel alignment (although it will cost you more)....
Thanks Zee, I took to back and had it adjusted some more. It's sits perfectly now, but I'm not too confident about the work that was done. I think they just kept adjusting to get the steering wheel straight and not concentrating on getting the wheels aligned.
Do you know how much the dealers charge for 4 wheel alignment?
