Good Bye Gs..hello Rx
hello, im chopping in my gs 300 for a rx 300 (2001),can anyone give me a checklist on what to look for and check....thanks piperdog
Always check for wheel corrosion ...
Mine, and not only mine!, is from 2002 and exhibits wheel corrosion on all four wheels. (Many owners suffer this same problem, check this forum, it concerns a standard deficiency on RX300's)
Lexus After Sales will never recognize this defect after exactly 3x 1 years. (= Out Of Warranty !)
"Rattling" of the dashboard is a classic as well, a pain in the a**, make sure that this problem was corrected whilst still under warranty.
Both of above problems would cost you a lot of money to correct if not dealt with before purchase.
Also, the dashboard and most of the interior (the inside of the 4 doors etc) is extremely sensitive to even the smallest scratches; you will not be able to remove them.
Otherwise, good luck!
