Fuel & Engine Oil Additives
Has anybody used the fuel additives claiming improved performance and cleaning properties, also has anybody used the PTFE engine oil additive.
If you read all they say on the packaging they are the best thing since sliced bread, mind you what was the best thing before they invented sliced bread.
i use octane boost every so often :yahoo:
Same here - for a bit of a zing I put in a bottle of STP Octane Boost in before filling a full tank (the CAT friendly one). Works a treat. :yahoo:
You can also use that Nitrox Power Shot stuff which is meant to clean out your engine too. It also works great, but I'd imagine it should be used pretty rarely if at all. Leave that to the Escort owners :arrrggg-matey:
