Does anyone know if there is an overhaul kit available for starter motors, specifically a '96 GS300? Just swapped mine over for a second hand unit so want to overhaul the one that came off. Symptoms were clicking from the solenoid, but motor not turning. After many key turns it would spring into life. A part number would be great.
Cheers
Rick
Sounds like the contacts in the starter are worn, it clicks until it finds a good contact then it works
there are 2 contact kits inside the motor
28226-74070 & 28226-22050
cost about £8 each
