What Oil Grade Do You Use In The Is200 Manual
DINO
Hi all,
Just wondering what oil and grade other IS200 manual drivers use and how often or how many miles later do you change the oil. Cheers
engine oil: 5w-30 or 10w-30 semi or fully synth. api sj,gf-2, ilsac certification
manual gearbox:api gl-3, sae 85w-90
engine oil if fully synth up to 10.000 miles semi synth.5000 miles
Gearbox: every 60.000 miles or if severe use/very wet envir. 25.000 - 30.000 miles
good luck
Hi all,
good luck
So is 10w-40 ok. Its Eneos (over 75% of japan use this oil). I tried 5-30 and thought it was a bit too thin. I may try 5-40. Your thoughts would be much appreciated.
