Set of LEDs off Mike Morse (Mr Morse) then some load resistors. Not cheap mind....
Yeah i remember Mikes group buy, but wasnt around much back then, cant seem to get hold of Mike over on ultrajap :question:
  • 2 months later...
Bump :whistling:
I got a set from Mike on my IS200 Sport. He had a contact in the States for LED's, including these but Mike has married Nicky (the lady that set up UltraJap site) and more or less relocated to Nigeria, so haven't a clue how to get hold of him. UltraJap is probably the best bet..suggest you pm the admin on the site for contact info.
Cheers for that Tango, tried PMing mike a while ago over on ultra jap......its a bit of a ghost town over there.....dont think anyone knew where mike was getting them from anyway, just wondered if anyone else knew of another supplier
Ta
i have a set that i've taken off the car now. They are complete with load resistors, and wire connections. Literally a plug and play job and no warning light will illuminate.
How much you want for them mate, how come you took them off? :)
Not sure if the same reason, but the reason I sold mine on was that there really was not a significant enough difference in brightness between sidelights and brakelights, which worried me slightly - having been rear-ended in the past, didn't really want to encourage it happening again.
I only fitted one to start with, and the standard bulb was so much brighter that I thought it wasn't worth the risk......
Ahhh....you got any pics showing the difference Parthiban?
Unfortunately no, sorry mate - hopefully one of the others might be able to swap back to an original bulb and get a pic?
The problem was that the majority of the LEDs point forwards, and the design of the rear light cluster works mainly off reflected light, so it wasn't making best use of all the light available........
similar reason. You can definitely notice the difference between lights on and lights off, but its not as much as with incandescent bulbs.
After i had the fog to brake conversion, i wanted a more equal bulb luminescence between brake and fog. so the only real option was to revert back to standard bulbs.
If you're interested in them, pm me an offer and we'll take it from their. Brand new, the bulbs are about £40-£45 and the load resistors about £10 if i remember correctly.
how much then?
  • 5 weeks later...
Hi Shaz,
I have a set of rear LED pulse brake bulbs complete with load resistors which I got from Mr Morse but never got round to fitting them on my IS300 and now I have chopped it in for a new LS460 SEL.
I also have a set or 20 LED indicator bulbs aswell, all cost nearly £80 from mr Morse but thay are just lying around doing nothing now.
PM me if anyone wants them.
