Wing Mirrors / Reversing Function
the motorised drive takes the angle down so you can seethe kerb-has the mirror itself moved within the glass? do you sit very low or very high in your seat? i think the mirrors could be adjusted so that they are as low as possible for normal use then they will dip to the correct level when reversing-other than that i'm stumped!
let us know if you find a better fix
