Need Help
Hi guys,
Two pictures below of the IS200 gearbox. Can anybody tell me which is the filler and the drain plug bolts.
I have a workshop diagram but it is completely different to my box.
Gearbox from underneath: - which is drain plug ?
Gearbox from underneath and left hand side: which is filler plug ?
Any help very much appreciated.
You should know this.When it drain,it has to be going down.Nothing drains up.It's the law of the gravitation.Read about Newton with the apple.
O.k. so which is it then ? A or B ?
A is the same bolt as the engine drain and B is the same bolt as the diff drain.
