Sat Nav Disc Location
can somebody pls tell me where i can find/locate the sat nav dvd tray-loader thing in my is300.
Basically i want to see what version dvd i have in my car.
thanks
I believe its located in the boot. lift the carpet to access your spare wheel and it should be on the right hand side
seen it before
thanks
Yes, the Computer Unit for the Sat Nav is located next to the spare wheel. It is covered with a metal plate, that is removed with two screws. Then there is a small sliding piece of plastic covering the eject button. You will need the keys in the ignition to eject the disc.
are they not the same as the older ones?
with the metal door flat, that you open and it ejects?
ugh, i hate it when there are new gadgets i dont have :(
*mumbles swear words at his old 99T*
