Is the radiator different for the I200 and Altezza?
I know the overflow tank/fan assembly is different..
Thanks,
Am.
I don't think so.
I recently bought a replacement radiator for my IS200 (standard) and it came labelled up as 'to fit Lexus IS200/Toyota Altezza'
The only difference will be is the core size, the OEM rediator has a 27mm thick core, where as a aftermarket radiator will have a 16mm thick core. Both will do the job.
You don;t think so but it was labelled to fit IS200/Toyota Altezza? Doesn't make sense unless you meant it fits both
where did u get it from anyway
I meant it will fit both, IS200 or Altezza.
Bought it from United Autoparts Distribution (www.uadweb.com)
Their website has a diagram of the radiator, so you should be able to confirm for yourself.
Thanks mate, i'll check it out... looks like theres 2 listed... i guess ones manual and other one is auto
On second glance, i don't think it will fit...
The lower rad pipe appears on the opposite side to mine... both top and bottom are on right side ( from the front of the car )
Have you tried to source one from eBay or northern radiators?
Can't you get your original one re-cored?
I might look into it, but in the past i've always just spent the lil extra and bought new ones!
