Took Tezz For A Plug In
scott-altezza
i took my altezza down to my local tunning clinic today and eventually got it plugged in and the codes that came up were
P1663- ocv circuit malfunction wich im told means oil control valve ?
P0710- T/m fluid temp sensor wich im told means transmission fluid tem sensor?
can anyone tell me were the transmission fluid sensor is located and also the OCV/oil control valve as ill check these and replace if needed.
also im needing the sizes of the front belts on the altezza as they are worn and need replaced if anyone nows , thanks scott
Not sure about the codes but what belts are you on about? Timing belt/power steering belt/ alternator belt?
