Help - Alarm Not Turning Off.
atailor
Hi All,
For some strange reason my key buttons were not working when I tried unlocking my IS200 a few moments ago. I stupidly used the key to open the car, as I should have guessed the alarm went off.
I have tried using the key buttons without success. To add to matter the hazards are fashing which will probably end up draining my Battery before the morning.
Does anyone know if there is a emergency alarm deactivation?
Anyone had this problem before?
Thanks in advance.
Amit. (atailor) :crying:
Okay I'm back - the lock-unlock-lock-unlock method did not work for me.
I read on another thread that the alarm should deactivate after 10sec after switching the engine on. So I gave it a go and drove the car with the alarm on. The alarm switched off after 10secs. I guess I was too quick when I first tried.
Worth noting for the future.
Key buttons still not working on both sets of keys. A trip to the garage I think.
Thanks again for your input guys.
Good night.
Amit (atailor). :hocus-pokus:
I had a problem with my alarm recently and, it wouldn't activate the siren and horn if you waved your hand around inside the vehicle after it had been armed. I took it to Lexus Reading and they had to fit a fit a new sensor - now fixed and all okay :D
I got chatting to the service manager and asked him if they had many problems with the alarms on the IS200, he replied that the only trouble they seem to have is that they don't always switch themselves off :excl:
So might be an idea to check the sensor. Just a thought.
