In the process of installing an extra low voltage shower.
Question is do I need to fit either ceiling switch in the bathroom or a wall mounted switch outside to isolate it for wiring regs. The transformer is fed through a DP Fused Outlet in the loft.
TIA
Prob best to fit one just on a "amount of electricity used" front.
Don't want it turned on all the time do you?
It won't draw any current unless the pump is running which only switches on when there is water flowing.
On a related note, I didn't think the Nanny State would allow you to do electrical work in wet areas these days - are you planning to have the work inspected afterwards? You may run into trouble when you sell the house otherwise...
