i put the car in for MOT today and all it needed was a number plate bulb :D so the guy passed it and told me to replace it so i edged a screw driver up the side of the cover from all angles and cant get it to move.Dont want to break the trim.Am i going about it wrong?
Alright dude, its posibly just stuck or wedged in, you could try taking off the trim inside the boot and knock it out that way. dont know if you can get it from there as ive never had it off but worth a shot.
i took off the lining and its sealed from the back i might need to take off the whole plastic strip that the 2 lights are fitted into?
No need to do that.
Did mine just today (changed to blue LEDs), undo the lining on the bootlid, and just behind the lock, you will see the two grey bulb housings, twist them off, and the plugs can just pull out as they are Wedge Type bulbs.
If you need more help, PM me and I could possibly do a quick DIY with pics.
