Window Washer
sercombe
My window washers on the windscreen arnt squirting any water. I can hear the motor buzzing as normal but no squirt.
1. I have checked and filled up the water to maximum.
What could it be? Does the buzz from the motor suggest that the motor is fine or can it still buzz and be broken?
your washer jets are probably bloked, get a needle/pin and push them into your jets on your bonnet (like your adjusting the angle) give them a little poke around and that may loosen any grit/muck in the jets.
my g/f has them on here polo, the short moment where your cleaning the windscreen you can't see s**t all! don't really like them but they do seem to do the final job better. plus she don't have unsightly jets on her bonnet.
on the sprinter and iveco vans they have a little clip that clip over the wiper arm that sprays a fan of water over the screen. im probably going to get a couple of them and clip on my wiper arms.
then when i have my bonnet sprayed il fill the holes where the bonnet washers were located.
