Alloy Offset
Hank B
Just lookin for some knowledge, I've spotted a set of wheels I really want, only trouble is I can only get em with a 40mm offset, they are 7.5x18 inches, would tehy stick out too much? anyone else got wheels with the same offset, any pics? cheers. :duh:
IS offset is 45-50
40 offset on 7.5 may fit but might rub if lowered
i have 7.5x18 on a 42 offset and they are perfect
Bazza,the reason they fit perfect is because they fall into the 38 - 45 offset guide NOT 45-50
38 - 45 is correct guide
See table
Offset guide
B)-->
QUOTE(T7RY B @ Feb 23 2007, 10:59 AM)
IS offset is 45-50
See table
Offset guide
So 7.5JX17 PCD 5X114.3 with an offset of 35 wont then? Sorry for the high jack.
Mine are standard "lexus" 17" 5 spoke .... and the "et"(offset) is 50, seen lots of guides on the net ..... some are very accurate others are not...
Also remember that clearence of the front calipers could be a issue as well as even on the stock rims it's very tight...
B)--><div class='quotetop'>QUOTE(T7RY B @ Feb 23 2007, 10:59 AM) </div><div class='quotemain'><!--quotec-->
IS offset is 45-50
See table
Offset guide
No
