Internet Shminternet
wildrnes
but you are at home, on the 'net with a beer?
gissa job??
:P :P :P :P
:lol:
I am actually mate!! Its not all plain sailing though - getting up at 6 can be a real pain in the *****. Coming home at 4 is tops though, and there is no traffic to contend with B)
nope
can I suggest that it was a PEBCAK issue?
mat can you sugest a solution
i click on explorer loads up home page (loc)
click on forums
it times out
go on explain which bit i did wrong ;)
if I were to diagnose this without any sight of your machine, I would guess that it sounds like a problem with your connection (work or home?)
basically, you are not connecting to the 'net - the home page and forum index are cached, and are being read from your hard disk.
When you try to access the forum, as there is no connection, it can't connect to the database.
I would say that there was a problem with a DNS server at your (companie) end.
It could be this new virus SQL Slammer - it affects servers. Loads of websites are running slow because of it :ph34r:
that would be a distinct possibilty Claire - except for the small fact that 'SQL Slammer' affects MS SQL Server databases on MS web servers, and LOC runs MySQL database on Apache web server..
an analogy would be a weakness found in the hull of the QE2 causing a problem on Concorde.
:D
QUOTE (wildrnes @ Jan 30 2003, 07:28 PM)
QUOTE
nope
click on forums
it times out
i cleared the cache to see if it was a prob.
i could go on other web sites and listen to the radio too
please not another day without loc
:duh:
...... an analogy would be a weakness found in the hull of the QE2 causing a problem on Concorde.
:D
I see,
so basically,
one's a boat, :geek:
and
one's a plane. :geek:
That makes it much clearer now.... :duh:
:D
I see,
so basically,
and
and how could something wrong with a boat affect the plane?
couldn't really.
if we say LOC is the plane, then the "boat virus" (sql slammer) can't affect it.
I had the same problem but it was all NTL'S fault for me! most of their servers were down. :( they tempt you in with a flashy 1 meg connection then it all goes pear shaped, come back BT-Brokenworld all is forgiven!!
