Just fitted new Mintex discs and pads on the front of the Tezza.
The "frame" that holds the caliper has 2 bolts that were a pig to "break", the ends of the bolts were a bit rusty, as you would expect. Like the title says anyone know what they should be torqued back up to?
TIA
Had the same Q for a few of my current & previous cars........Tight As Fook seemed to be the most common response :duh:
Yup I went for "eyeballs bulging and veins in the neck exploding" tight :lol:
I have: Front 118nm and rear 104nm.
Tony, Did you work that from the thread size? Just wondering if it's the same for the 250 :unsure: 'cos I'll need to know by the week-end :whistling:
The information is from my Autodata cd... the 250 is not included yet (sorry).... Although dare i say it! i think it will be the same.
Thank you Dr Bones, I will now be giving them a check up ASAP. 115nm with a 300mm bar is a lot of sweat :D
What with a big boy like you.......Naaaaah
From a Woman I would take that as a compliment :lol:
Thinking about it, and getting the calculator out, maybe I over did it a shade :D
Probably best! In a perfect world the bolts are meant to be replaced with new ones! I think most would agree educated cutting of corners is realistic.
