Clutch Problems, Rattleing Noise
Baba
can anyboady help? i have a annoying rattleing noise which seems to be comming from the clutch, When at idle the noise is present if you depress the clutch the noise disapeers . when driving and changing in the lower gears the clutch tends to be slightly jerky. Took the car back to the dealear one of the machanics took the car for a drive, he said that there was nothing wrong with the car its just drivetrain noise which most is200 get? dose anyboady else have this problem or know how to solve it?
Hi
Jerks lower down the gears are a common floor with the IS200 do a search and you will find plenty of info its nothing really to worry about just something you get used to as for the rattles that may be a seperate matter
the noise is almost certainly the relaease bearing (also called thrust bearing) on the clutch mech, and is part of a standard clutch kit (clutch, pressure plate, release bearing) when you have a clutch change, make sure that this is changed too. a nosiy bearing is usually just an annoyance and will cause no problems other than the noise.
