Plastic Parts In The Engine Bay
GWilso
Evening all
I was cleaning out the air filter today and noticed the plastic surround around the the oil filler (the surround with the VVTI logo) cap is badly crumbling away presumably under the heat has anyone else had this? is it dangerous should i have it replaced?
I've seen crumbling plastic before, but not in a car. Was the front face of an uninterruptible power supply that a plug-in air freshener had tipped onto. I believe the process is known as catalytic embrittlement. Glycol-based brake fluid can do this, I don't know about engine oil though.
