It Cant Be A Fuse (indicators Revese Lights + More )
Have you actually checked all fuses???
my mission today was to pull all the fuses and physically test them one by one...........you were right .after checking all the engine ones ( again ),then pulling and checking the passenger footwell ones,i found the culprit in the drivers side :D ....time well spent,must say the hand book was as much use as a chocolate spoon..BIG THANKS :tsktsk:
