It you fit an induction kit or the likes it is recommended by the manufacturers of these devices to fit one of the above or similar to adjust the sensor to the ecu readings in order to get the full benefit of the modification...
What I've been lead to believe is that they are a waste of money as the ECU tunes it out after awhile.... so unless you were happy to keep resetting the ECU every couple of weeks then give it a miss
