Jap To English
elexes
I was just about to put babelfish :D
The translation as a block is below, you may have to do it line by line. it doesn't recognise trade names or very technical terms
Engine system * metal: PWR F? 1 black metal * head gasket: PWR heavy metal head gasket * turbine: PWR PE2020M turbo KIT * injector: PWR SH550 injector * fuel pump: PWR 255L/H fuel pump & timing belt: PWR super strong II timing belt * ラジエター: PWR ダブルローラジエター * ラジエターホース: PWR ラジエターシリコンホース *: PWR air impulse II * belt: PWR super V belt * ECU: PWR original ECU & filter: PWR magnetic power II oil filter Exhaust type * muffler: PWR φ 76.3 supersonic silencers - Drive system * clutch: PWR twin plate clutch Wrapping system * front bumper: ドゥーラックフロントバンパースポイラー reforming * side step: ドゥーラックサイドステップ reforming * rear bumper: ドゥーラックリアバンパースポイラー reforming * bonnet: Shift sport carbon bonnet * fender: Shift sport aero fender Interior system * meter: PBC (power boost controller) * meter: FSC (fan switch controller) Underside system * suspension kit: PWR パワーズダンパー PRO full KIT * rotor: PWR カーボンスリッドローター * brake pad: PWR RS550 brake pad * wheel: ヨコハマ AVS model T7 * tire: Yokohama Rubber Co., Ltd. アドバンネオバ
Google also do their own version of Babelfish as well - http://www.google.com/translate
Pretty much comes up the same:
ngine system
  * Metal : PWR F-1 black metal
  * Head gasket : PWR heavy metal head gasket
  * Turbine : PWR PE2020M turbo KIT
  * Injector : PWR SH550 injector
  * Fuel pump : PWR 255L/H fuel pump
  * Timing belt : PWR super strong II timing belt
  * [rajieta] : PWR [dabururorajieta]
  * [rajietahosu] : PWR [rajietashirikonhosu]
  * : PWR air impulse II
  * Belt : PWR super V belt
  * ECU : PWR original ECU
  * Filter : PWR magnetic power II oil filter
  Exhaust type
  * Muffler : PWR φ76.3 supersonic siren sir
  Drive system
  * Clutch : PWR twin plate clutch
  Wrapping system
  * Front bumper : [douratsukuhurontobanpasupoira] reforming
  * Side step : [douratsukusaidosutetsupu] reforming
  * Rear bumper : [douratsukuriabanpasupoira] reforming
  * Bonnet : Shift sport carbon bonnet
  * Fender : Shift sport aero fender
  Interior system
  * Meter : PBC (power boost controller)
  * Meter : FSC (fan switch controller)
  Underside system
  * Suspension kit : PWR [pawazudanpa] PRO full KIT
  * Rotor : PWR [kabonsuritsudorota]
  * Brake pad : PWR RS550 brake pad
  * Wheel : [yokohama] AVS model T7
  * Tire : Yokohama [gomuadobanneoba]
