Key Fob Battery
Battery type is in the handbook, IIRC CR1616 :question:
And yes easy to change, you will need cross head precision screwdriver as well. And watch the screw that holds the case together at the end of the key blade, can be a bit stubborn so use the proper driver.
Edited by MacRS200
once the battery has been changed does it need to be re-registered/synchronised to the car?
Not if you do it quick enough. At least thats the case on the Scorpio (You have 20secs), not had to change the Lex one, its done on a service.
