Voice Commands
Infinity
I'm struggling with getting the car to understand Geordie so please help me out and post up any voice commands you know work, also your acent or inflection on the command may help
I'll start the list off.
Warmer Turns up the climate control 2 degrees (If dual zone is set this applies to the driver side only.
Cooler Turns down the air con 2 degrees Only works intermittantly dont know why (emphasize COO)
Automatic Air Conditioner On/Off Turns the aircon on or off
DVD or DVD Changer Switches to CD or DVD Mode
FM1/FM2/FM3 or FM 1 Radio/Long Wave Radio/Medium Wave Radio Switches to the Radio preset first 6 second six etc. preset channels and selects the last used station.
Seek Up/Down Scans for radio stations.
Next Track Moves forward 1 track on the CD or DVD
Previous Track Moves back 1 track on the CD or DVD
Next Disk Moves 1 disk up on the CD or DVD
Previous Disk Moves back 1 disk on the CD or DVD
More please.
Infinity.........
More please.
Nest time you press the voice command button, look at the screen. There is a help button there, just press it and all voice commands are listed/ :duh:
Infinity.........
More please.
Next time you press the voice command button, look at the screen. There is a help button there, just press it and all voice commands are listed/ :duh:
Infinity.........
Yeah that works but there are others in the system that you have probably found that are not listed this is what we need.
In addition to those listed above, I also use these:
Food - lists restaurants
I'm Hungry - as above
Go Home (as opposed to just Home) - sets navigation to Home Quick Route 1 normally
Mark Point - blue flag indicator for a spot you want to pin
Quick Route 1, 2 or 3
One or two may be listed in Help, but they are the ones I usually use. I too would like to see ones people have stumbled upon.
  • 5 months later...
There's all the usual ones like
"Airports" - shows Airport Icons
"Petrol Stations", - shows petrol station icosn
"Car Parks" etc, etc, etc
Then there's "Zoom in/Zoom out" (does what it says to map display)
"Screen Off" - Does exactly that !!! (to turn it on say something like "Map mode" to bring up the map)
"Heading" changes the mode to North up or heading up mode
"Suspend Guidence" and "Resume guidence" does exactly that (this saves the GPS recalculating the route if you pull off into services or into a petrol station etc. It retains the route even after turning the engine off. When you jump back in just say "Resume guidence"
I shall think of some more I regularly use later...
Cheers
The Ed
Found these for a previous generation Lexus, anybody want to try a few (I've extracted them from a couple of .pdf files, so apologies if I've lined them up wrong ):-
Various
Command Action
Louder Turns volume up 1 level.
Softer Turns volume down 1 level.
Voice Guidance OFF Turns voice guidance off.
Voice Guidance ON Turns voice guidance on.
Audio mode change Radio operation
Command Action
Radio Changes to Radio mode.
AM Changes to AM mode.
FM Changes to FM mode.
FM 1 Changes to FM 1 mode.
FM 2 Changes to FM 2 mode.
CD Changer Changes to CD Changer mode.
Radio operation
Command Action
Seek Up Seeks Up.
Seek Down Seeks Down.
Changer operation
Command Action
Track Up Plays next track.
Track Down Plays current track
Previous Track Plays previous track.
Disc Up Changes to next disc
Next Disc Changes to next disc
Disc Down Changes to previous disc.
Previous Disc Changes to previous disc.
'Warp factor four' does, but the traffic cop on the M4 today didn't believe me
Then tried 'Beam me up Scotty' but unfortunately that didn't :D
The second generation IS is getting too common...there were three of us in a convoy on the M4 today.
  • 9 years later...
18 minutes ago, rayaans said:
Not really tried it so can't say! I think its a bit of a faf really, prefer to just put it in manually!
Just a bit rubbish of Lexus in my view,  voice recognition what's the point if it then!  Going to post on Lexus FB page next
