I have a 2002 IS 200 and the Tail/Brake failure warning light keeps coming on intermittently even though the bulbs are all working. I have replaced the bulbs but still no joy and I am getting annoyed now...
Can someone please help? Where the connectors etc ???
Which bulb(s) did you replace?
If the warning light on started after you replaced the bulb then it must be a bad connection.
I replaced the tail/ brake light. The problem is , it happens intermittently
It will do with a bad connection...try checking the alignment of the pins on the bulb
