For a week now, I have started to hear a knocking noise on the right front side.
It is happening more and more on road bumps and turns.
I lift the car this morning and noticed this :
Can I change just the bearing or do I have to change the whole arm ?
How dangerous is it to drive with this ?
bushes are not sold apart so I ordered 2 new arms :(
Thats odd they have gone
Do you have chassis braces on the car?
Tanabe chassis braces, rear strut bar, and I used to have front strut bar before I install the supercharger.
I have Hotchkiss sway bars set to the stiffest, KW coilovers set low and stiff (80% of the max).
I have just changed the 2 bars :
The bush was not dead, just cut on a little part. And the worst is that the knocking nois is still there.
I can't find where it comes from :( I checked both front and rear bushesand none is destroyed.
A friend of mine told me it could be the steering :wacko:, it seemed to happen on renault 21 turbo. I will try to look at that tommorrow if it does not rain
Yes but I was not sure about TRD bushes delivery date and availability and I don't have the tools to take the old bush out :(
I just checked the steering and all is fine.
Hi, is this a loud knocking noise, or a creak ?
I have an issue where my IS300 developed a knock on the front right, the dealer replaced both front shockes... the knocking noise went... but now after 6 months I have a creak... and clicking noises when turning left slowly... from the front right strut. The dealer can't say for definate where the issue lies.
Anyone seen this ?
The noise is quite loud like if something hurts the chassis, it is not a metallic noise.
I rechecked my antiroll bars fixations and all is ok but I have noticed this : the bars have marks and there is some red on the edge of the chassis part. Could it be this ? I can't figure how it can occur, the car is very stiff.
it does look like ARB is touching the under side at points.
try taking it off have a drive about and see if the sounds still there
at least that way your eliminating what it could be making the noise
  • 1 month later...
Hello Everybody. I own a 99 IS 200 and have the same knocking, creaking noises mostly when making turns. I am the original owner and noticed the noise some time ago. I wonder if the shocks need to be replaced?
Anybody else?
Greetings from Switzerland.
Cheers
Schumi
Anybody else?
Cheers
Schumi
Great user name B)
No i wouldnt say its the shocks,if the ride is floaty and theres a lack of body control,then id say the shocks are on there way out.Id say the problem is as posted above.
Chips..
