Nothing major. Just a couple of dodgy brake pipes near the rear subframe. Quite badly corroded though and the Fuel pipe could do with changing as well.
Not to bad then could have been alot more money if it failed on any suspension parts etc.
Good Luck with the retest :)
Chips..
3 new copper brake pipes fitted and its all done, dusted, retested an passed.
I do have some bad rust starting to form around the rear though.
Next weeks plan when im off is to get treating it with the deruster and good ole Waxoyl and Hammerite.
Hopefully it should last another Ten years.
Front suspension joints are fine. Its all been replaced.
