Help Needed
Just wired in my sat nav housing
Constant to top right
Ignition Bottom right
Ground Bottom Left
on output pins on the back
Now the bloomin thing will only go down in a few phases it wont go up at all.
Anyone got any ideas
CHeers
Can't help with this I'm afraid but I always find that it's best to go and sleep on it. Then maybe start again from scratch.
I fitted a new house alarm the other day which refused to work - spend 3 hours looking at it then gave up. Next day ripped it out and started again, and bingo - worked fine....
Good advise, but still dont know whats wrong with it, it goes down a bit then stops then press either button agian then goes down a bit and stops over and over untill it closes
Really havent got a clue?
Where'd you take your constant from? Found this with the EDFC, wired it from the radio and it powered up intermittently. Found a live in the passenger footwell, now works fine.
Lee.
Got a live straight from the Battery as this is used for my headunit as well. getting a bit annoying now having a fiddle at the moment
