Stainless Steel Brake Lines
maneesh
Stainless steel brake lines. Anyone fitted them to their car, in particular a GS? Apparently, they remove the spongy feel to brakes as well as improving performance? Is this true?
Thanks.
We sell them for £48 plus vat per set.
Mark :)
The stainless braiding should reduce expansion of the flexible brake pipes when they are pressurised under braking.
So in theory that will reduce "sponginess" in the brake pedal caused by the spring effect of the hoses expanding. It should also enable higher pressure in the fluid increasing brake efficiency.
