Is200 Dome Light Change?
Im trying to change the bulb on my IS200 rear dome light, the one behind the sunroof. Do you just pop the lense out with a screw driver? didnt want to break anything trying to force it,
cheers
Hi. Yes that's right. I did mine. It's very easy. The front one it more tricky though. You will need a 31-35mm Festoon bulb for the dome and a BA9 for the map light :)
  • 4 years later...
