Creeky Clutch Pedal
The clutch pedal in my IS has developed a creek/stiffness that I can feel in my foot when I drpress the pedal. You can hear it a bit when the stereo is off.
I'm guessing that the spring may just need some lubrication...is that possible??
If so what would you guys recommend, I would think of WD40 as more of a temporary fix...so what would be the best thing to use?
Cheers - Neil :)
i started a thread on this, arlier today too, lol, seems like wd40 does the trick
Not for long tho, mine comes and goes its really strange, i found where it was coming for and put grease on it, its got a rubber surround that you pull back and its under that, mine started squeeking agian not long after tho and now has gone.
Hi
I had this on a previous car, WD40 worked for a while but all started up again in the summer, i used a 3in1 spray with ptfe (i think) that did the job, also fixed the interior fan from screaming at me.
